Have another problem when it comes to rendering. Nothing reneders and here is my code from renderlog:
3/30/2015
Starting "C:\Program Files\Autodesk\Maya2015\bin\mayabatch.exe"
Initialized VP2.0 renderer {
Version : 5.3.1.800. Feature Level 4.
Adapter : NVIDIA GeForce GTX 770
Vendor ID: 4318. Device ID : 4484
Driver : nvoglv64.dll:9.18.13.3788.
API : OpenGL V.2.
Max texture size : 16384 * 16384.
Max tex coords : 8
Shader versions supported (Vertex: 4, Geometry: 4, Pixel 4).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 2048 MB.
CPU Memory Limit: 15505.9 MB.
mental ray for Maya 2015
mental ray: version 3.12.1.16, May 6 2014, revision 219245
1 error generated.
Error while processing C:\Program Files\Autodesk\Maya2015\plug-ins\bifrost\db\presets\__rootincludeall__.h.
Time: 2015/3/30 19:55:43
Result: externalContentTable
Warning: line 1: Selected nodes were ignored since the 'scene' flag was used.
Result: 1
File read in 0.53 seconds.
Result: C:/Users/Michal/Documents/maya/projects/Introduction to Maya 2015/scenes/moja_mech1.0042__8568.mb
Warning: (Mayatomr.Scene) : output data type "rgba_h" not directly supported by image format tga, conversion performed by mental ray
WARNING: local IMF plug-in `C:/Program Files/Autodesk/mentalrayForMaya2015/bin/image/IMFmentalrayCT.dll' overrides `C:/Program Files/Autodesk/mentalrayForMaya2015/bin/image/IMFmentalrayCT.dll
WARNING: local IMF plug-in `C:/Program Files/Autodesk/mentalrayForMaya2015/bin/image/IMFmentalrayMAP.dll' overrides `C:/Program Files/Autodesk/mentalrayForMaya2015/bin/image/IMFmentalrayMAP.dll
WARNING: local IMF plug-in `C:/Program Files/Autodesk/mentalrayForMaya2015/bin/image/IMFmentalrayST.dll' overrides `C:/Program Files/Autodesk/mentalrayForMaya2015/bin/image/IMFmentalrayST.dll
API 0.0 29 MB error 301189: group :MayaTranslatedWorld: instance "fluid1" unknown, cannot resolve
PHEN 0.7 62 MB warn : Color Mgt: Only support RGB & A
PHEN 0.2 74 MB warn : Color Mgt: Only support RGB & A
PHEN 0.6 74 MB warn : Color Mgt: Only support RGB & A
PHEN 0.10 91 MB fatal 051109: runtime exception 0xc0000005: access violation
PHEN 0.5 91 MB fatal 051109: runtime exception 0xc0000005: access violation
// Maya exited with status 2
Any ideas?
