Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
can't render Fluid behind refraction object?
4 REPLIES 4
zouheirito
369 Views, 4 Replies
do this test...
create fluid smoke inside sphere or cylinder or any object, make this object transparent after assigning any shader you like, if you try to render it will work...
try to active from Raytrace tab " refraction", theorly if you make the refraction value as 1 it shouldn't give any refraction effect, but if you try to render, the fluid will be disppeared .................
why???????!!!!!!!!!!!
4 REPLIES 4
_sebastian_f
in reply to: zouheirito
if you want to have transparency but no "refraction effect" you should change the index of refraction (IOR) in the settings of your shader but not lower the trace depth in the render settings.
tonymail
you need enable autovolume in mental ray feature tab
zouheirito
in reply to: tonymail
it didn't work buddy. try it by yourself if you like
_sebastian_f
ouch my bad sorry.
tonymail is right. autovolume should be enabled and i should have had a better look before. in the render stats of your fluid shape enable "visible in refractions (and reflections)". anyway refraction appearance should be controlled in the shader then. just wonder why you wrote it worked before changing the refractions to 1. btw. it also makes a difference if you use maya or mental ray shaders.
