do this test...
create fluid smoke inside sphere or cylinder or any object, make this object transparent after assigning any shader you like, if you try to render it will work...
try to active from Raytrace tab " refraction", theorly if you make the refraction value as 1 it shouldn't give any refraction effect, but if you try to render, the fluid will be disppeared .................
why???????!!!!!!!!!!!
