Has anyone set up a Room Tag to include occupant load factor and # of Occupants, I have a fair idea in creating the labels bu unsucessful in getting it to work since I am trying to use the Area parameter in conjunction with the OLF parameter to get a calculated value to the # of Occupants? Any ideas is greatly appreciated.
KIm
Solved by GlynnisVP. Go to Solution.
The OLF in a tag is fairly straightforward. It just needs to be a Shared parameter, most likely a "number" format. It's the number of occupants that will be elusive as Revit doesn't allow a Calculated value to be part of a tag. I can send you the sample file that I've used in this video if you'd like.
http://www.youtube.com/watch?v=R50XzC3ghO4&feature=share&list=PL19262EC9FFAC7422
Glynnis Patterson, Architect
www.ideatebimlink.com | www.ideateexplorer.com
