Sometimes when I try to load a family in the project I get this message (see the attachment).
Why? and what is the solution?
Thanks.
Solved by Alisder.Brown. Go to Solution.
Solved by loboarch. Go to Solution.
jz4all
Above post answers your question.
Best way to load families into a project is to go to the "Insert" tab on the ribbon and use the "Load Family" button there. Before you do this, MAKE SURE no command is active (hit [esc] a couple time before you do this)
This allows you to load ANY family category in. So you wont see that message.
Hope this helps 🙂
I've long wished Revit was smart enough to just load it anyway on the assumption that if I tried to load it, its because I actually want it in my project.
