hi, is there anyway in maxscript to create an array of points, like an array contains pt1, pt2, pt3, so I can easily access them by a loop? Thank you!
Solved by Steve_Curley. Go to Solution.
http://help.autodesk.com/view/3DSMAX/2016/ENU/?guid=__files_GUID_A5B54C67_BFDD_45C0_9D6B_E6869817282...
A word of advice - always check the help first. Much quicker than waiting for someone to answer here, especially for a basic question like this one. The page linked above has many examples of how to set up and use arrays.
