Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Springs
6 REPLIES 6
JohnD7810
820 Views, 6 Replies
Springs
Ive been trying to figure out how to succesfully make a spring in maya i havent succeded in making one any help is appreciated
i am trying to make a spring like in the picture
6 REPLIES 6
dougj7
in reply to: JohnD7810
I don't know if I'm over simplifying this, but wouldn't Create>PolygonPrimitives>Helix work?
Anifex09
My favorite way to make a animatable spring is to use a tool found in Maya Bonus Tools - Create - Create Spiral Curve. Then just create a circle and extrude it along the spiral. You can then scale the spiral curve without deforming the spring.
JohnD7810
in reply to: Anifex09
were do i find the bonus tools
JohnD7810
i did find the bonus tools but how do i extrude along the spiral
Anifex09
1. Create your spiral Curve
2. Goto Create - NURBS Primitives - Circle
3. Select the Circle then shift select the Spiral Curve
4. Goto Surface- Extrude [option box]
5. set style to [Tube] - Result position to [At path]
set Pivot to [Component] - and set orientation to [Profile normal] - if you are using polygons set the Output geometry to Polygons - set Type to Quads - Tessellation method to General - use 16 for the U and 200 for the V - apply
JohnD7810
Thank you Anifex09, your solution works for big springs, but i think i like dougj7's way better
thanks for the help i appreciate it much
