I am creating my own .obj exporter for maya.
When i'm exporting just one mesh my code works just fine but when exporting several meshes / objects it fails to create the complete meshes.
I'm pretty sure that the problem is when i'm getting the face.getVertices(), face.getUVIndex() and face.normalIndex() and printing them to the file. As i said the first mesh works fine but when it gets to the second mesh the codinates gets all wrong, they connect to the wrong triangles. If anyone has any ideas on how to possibly loop them differently or change the values to the correct ones i would be forever greatful. Help would be very very appreciated!
Here is an example on how a multi object mesh ends out. http://postimg.org/image/rr0fvs0v7/
import pymel.core as pm
import pymel.core.nodetypes as nt
planes = pm.ls(sl=True)
def meshFile():
def myRound(n):
return round(n, 6)
file = open("C:/Users/Blondiegirls/Desktop/test2.obj", "wb")
file.write("mtllib test2.mtl\r\n")
for p in planes[:]:
#pm.polyTriangulate(planes[0])
file.write("\r\ng default")
# Printa world kordinater
for index, point in enumerate(p.vtx):
temp = index,map(myRound, point.getPosition(space='world'))
file.write("\r\nv ")
file.write(str(' '.join(map(str, temp[1]))))
# Printa texture kordinater
mesh = pm.ls(sl=True)[0]
U,V = mesh.getUVs()
UVs = zip(U,V)
for uv in UVs:
file.write("\r\nvt ")
file.write(str(uv[0])+" "+str(uv[1]))
#printa normals
for n in p.getNormals():
file.write("\r\nvn ")
file.write(str(n[0])+" "+str(n[1])+" "+str(n[2]))
file.write("\r\ns 1")
file.write("\r\ng ")
file.write(str(p))
file.write("\r\nusemtl test")
for faceIndex, face in enumerate(p.faces):
faceVertices = face.getVertices()
faceUV0 = face.getUVIndex(0)+1
faceUV1 = face.getUVIndex(1)+1
faceUV2 = face.getUVIndex(2)+1
faceNor0 = face.normalIndex(0)+1
faceNor1 = face.normalIndex(1)+1
faceNor2 = face.normalIndex(2)+1
file.write("\r\nf ")
faceVertices0 = int(faceVertices[0])+1
faceVertices1 = int(faceVertices[1])+1
faceVertices2 = int(faceVertices[2])+1
temp3 = (str(faceVertices0)) + "/" + (str(faceUV0)) +"/" + (str(faceNor0)) + " " + (str(faceVertices1)) + "/" + (str(faceUV1)) +"/" + (str(faceNor1)) + " " + (str(faceVertices2)) + "/" + (str(faceUV2)) +"/" + (str(faceNor2))
file.write(str(temp3))
file.close()
meshFile()
def MTLFile():
file2 = open("C:/Users/Blondiegirls/Desktop/test2.mtl", "wb")
object = cmds.ls(sl=1)[0].split(':')[0]
#print('object: '+object)
shipTX = pm.PyNode(object)
shadingGroups = shipTX.shadingGroups()
sg1 = shadingGroups[0]
material = sg1.listConnections(source=True, destination=False, type=nt.Lambert)[0]
file = material.color.listConnections(type=nt.File)[0]
filename = file.fileTextureName.get()
materialColor = material.getColor() #for Kd
materialAmbient = material.getAmbientColor() #for Ka
materialSpecular = material.getSpecularColor() #for Ks
refractiveIndex = material.getRefractiveIndex() #for Ni
file2.write("newmtl "+"test"+"\r\n")
file2.write("Ka "+str(materialAmbient[0])+" "+str(materialAmbient[1])+" "+str(materialAmbient[2])+"\r\n")
file2.write("Kd "+str(materialColor[0])+" "+str(materialColor[1])+" "+str(materialColor[2])+"\r\n")
file2.write("Ks "+str(materialSpecular[0])+" "+str(materialSpecular[1])+" "+str(materialSpecular[2])+"\r\n")
file2.write("d 1.0\r\n")
file2.write("Illum 2\r\n")
file2.write("map_Kd "+filename+"\r\n") #for map_Kd
file2.close()
MTLFile()
