Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Reflaction not rendering in Mental ray!!??
17 REPLIES 17
Message 1 of 18
telmog
1307 Views, 17 Replies
Hi
I have applied a very reflective shader (first Phone, then Blinn, mia_material_x set the chrome) on a plain (it show be a mirror with the high reflectively I have given it). And in Maya Software it is a mirror in render but in Mental Ray it is not reflecting a thing except for some geometry, badly.
YES I HAVE RAYTRACING ON! and I cranked the setting very high.
Can any one out there please fill me in on what I'm doing wrong!
Thank you.
With Targa for Image texture
xx2.jpgxxx2.iff
 With jpeg for image texture
My render settings
17 REPLIES 17
Message 2 of 18
damaggio
in reply to: telmog
It's hard to see in your small image ... Can u zip the file and post it here?
Message 3 of 18
telmog
in reply to: damaggio
HI
thanks for replying!
here is the .ma file ziped
Jim
Message 4 of 18
damaggio
in reply to: telmog
Thanks Telmog...here's the things to fix...
The sphere for reflection has to have an image applied to a surface shader out color not a lambert (this method is really not professional either, you should be using an IBL sphere with mental ray and an HDR spherical image and linear workflow)...having said that you can still use this old method and get away with a nice image.
The mia chrome settings should have diffuse 100% black , weight to 1 and BRDF 0 degree to 1
Use Final gather and raytracing
Blinns are more tricky and inaccurate because you have to set the reflection limit to at least 3 and Lights  should always have   Ray depth limit to at least 3....the Mia x doesn't have this problem because is a physically accurate shader and ideal to use with Mental ray.
Keep on going.
Message 5 of 18
damaggio
in reply to: telmog
here's one render
Message 6 of 18
telmog
Thanks so much damaggio
great insight!
I'm still a bit confused about one thing thou. The sphere is only being used to have something for the plane below to reflect. That the sphere has a lambert shader is not something I would be of consequence.
Message 7 of 18
damaggio
in reply to: telmog
Sure, just apply the  the chrome mia to both sphere and plane...now your scene had a rectangular cube and a flat plane sitting on top of it, don't know why you had two objects there. also your lambert sphere with Background image is not gonna be providing any lighting for the scene "just reflaection" and you didn't have any lights set up inside the sphere...you gonna need fianl gather in there.
Message 8 of 18
telmog
Hi damaggio
I'm Still having trouble. Please see my .ma zip file.
Message 9 of 18
damaggio
in reply to: telmog
directional  light angle is for soft shadows, your value is way too high ..maybe around .5 ray depth limit as mentioned before 3 light cannot go thru sphere if you dont disable sphere cast shadows in render stats.
do not put any maps for reflections in the mia...its chrome already so its reflecting everything.....your scene is way to large which means you gonna have to enter insane values for the lights...I have reduced it also lights should have quadractic setting.
Message 10 of 18
telmog
Thank you for the .ma file. But I was not able to open it properly, the scene is empty. Something got lost in translation.
So its because of the lights and scene scale that the mia material on the poly cube or plane is not reflecting a thing in the scene?
Message 11 of 18
damaggio
in reply to: telmog
I just unziped it from my post and is all in there, give it another try...its maya 2015 try to open with ignore version checked.
Message 12 of 18
telmog
I did open it with ignor version turned on. but it still gives me an error massage "Warning: Errors have occurred while reading this scene that may result in data loss"
can you export an fbx or save as maya 2011 ?
Message 13 of 18
telmog
demaggio
I'm still scatching my god-dame head bold!!!!!!!!   I gave to smaller sphere a surface shader, and a hdr texture to the out color. I set the mia_materal I want to be a mirror to all the setting you sugested!
Why Im I still not seeing one single ioda of a god dame REFLECTION!!!!!
Message 14 of 18
damaggio
in reply to: telmog
oKay Telmog, no need to loose your hair, I m gonna guide u thru this again.
Create a sphere as background ,under render stats uncheck cast shadows...assign surface shader and put an image into Out Color
Create a blinn color black , reflection 1, Eccentricity .055  specular roll off to 1 specular color white
reflection limit of blinn 3
Create a directional light Use raytrace shadows Ray depth limit 3
In Mental Ray set to raytrace, reflections 4 refraction 4 trace depth 10 shadows 4
Render...if that works for you then you can switch the blinn for a Mia X
Message 15 of 18
telmog
here's what Im getting
RRR.tga
Message 16 of 18
damaggio
in reply to: telmog
there's trees in the background and then there's a kitchen reflection on the sphere, doesn't look like what I told u to do.
Message 17 of 18
telmog
If I don't have a texture aplyed to the BG or spire that will the plane have to reflect?
Message 18 of 18
michel_men
in reply to: telmog
you don't need any Light in Scene, only MR, IBL and Mia Material X with Chrome Settings. FG is also not a must have, only default Render Settings.
Make it as easy as posible!
PS
U can put any HDR-File in the MR-IBL Node to reflect in Mia Material...
