when using a selected axis handel on the move to or any manipulator. sometimes I can have a object offscreen and need to reset the handle to all axis. To my knowledge there is now default hotkey for this. I did however find that in the MTK there is a button and that button triggers the command :
dR_setActiveTransformAxis 3;
This command takes any manipulator back to all 3 axis being active.
My Problem is however that I cannot get this to trigger from a hotkey. I have tried assigning it to numerous keys and cannot get it to trigger. I can however execute it from the command line. What gives? is this a bug? I mena I should be able to execute andy command from a hot key. I have tons of hotkey macros and scripts bound to keys. Why does this one command not work from a key press?
I just tried this and was able to create a custom script with your command using the Runtime Command Editor section of the hotkey editor. Create your script, give it a name, and save it.
Then choose Edit Hotkeys For->Custom Scripts. Your newly created script will show up in the list. You can then select it and assign a hotkey to it...
