Hi
I created my deployment and ran the installation and this has been on my screen for about 4 hours now.
What is it and should I cancel it? Note task manager says it is running
Your Name
Your Name
Solved by Joe-Bouza. Go to Solution.
Solved by emily.xu. Go to Solution.
Solved by TravisNave. Go to Solution.
Good question...
This isn't a silent deploy is it?
Also, is there anything in the installation log at that real-time moment that shows it's stuck on something?
Your Name
Your Name
It might work better if it is not a silent deploy. The only other thing that stands out is the potential that your UNC path may be too long during some point in the install.
Your Name
Your Name
Travis is right, we don't recommend to install under silent mode, so we can check where is the installation stuck or fail.
Another suggestion from me is to disable anti-virus , not only can it slow down the installation process, but it can actually introduce corruption. So make sure that your virus checking software is turned off before you install, and make sure you turn it back on when you're complete.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I don't think the dialog box caused a problem. The license errors I was recieving went away. IT told me they updated the License and they did not. Sometime you have to take the bull by the horns all the way into the barn.
Thank you all for the advice I am taking the silent mode off in the deplotment.
Your Name
Your Name
