Installation & Licensing
Does Autodesk work with lmadmin?
11 REPLIES 11
Message 1 of 12
2617 Views, 11 Replies
Apparently, lmadmin is no longer available at the Flexera site - http://www.globes.com/support/fnp_utilities_download.htm
"Users of FlexEnabled software must contact the publisher of that software to obtain license server managers (lmadmin and lmgrd) and related utilities (lmutil and lmtools)."
I can't find any reference to lmadmin at autodesk...does this mean that I can't use lmadmin with autodesk 2015 products?
11 REPLIES 11
Message 2 of 12
TravisNave
It works great.  I have a howto on it.
http://forums.autodesk.com/t5/Installation-Licensing/Installing-the-FLEXnet-License-Administrator/td...
The guide was created from a few releases back, but essentially it is the same thing and will work, so long as you use adskflex.exe version 11.12 as your vendor daemon for 2015.  Let me know if you run into any issues with the guide being outdated.
Autodesk Forums:
Message 3 of 12
DarrenP
in reply to: TravisNave
yes i can confirm that it works
but Autodesk does not support it for their products
DarrenP
Message 4 of 12
in reply to: DarrenP
Thank you both for your answers..
Even though autodesk doesn't support lmadmin that doesn't mean i cant use it right? If that is so, where could i get lmadmin, if it's no longer available at flexera's website?
Message 5 of 12
TravisNave
Yes, you can use it.  Just keep in mind that it is not officially supported.  So that means if you end up having issues, you'll get poo-poo'd.
From a quick Google search, it appears that you can still download v11.12.1.1 here.
Good Luck!
Autodesk Forums:
Message 6 of 12
getting poo-poo'd over here...
i followed the guide on how to install lmadmin, but i can't get adskflex to run. I get this error:
20:48:34 (adskflex) EXITING DUE TO SIGNAL 32 Exit reason 9
20:48:35 (adskflex) cannot create semaphore lock (Global\LM_adskflex_SEMAPHORE): 5
In the server where I installed lmadmin, i'm also running lmtools, could this be the problem?
PS: The reason I want to use lmadmin is because its user interface is better than lmtools....would I have an alternative to lmadmin? I wish there was a kind of dashboard to check which licenses are active, which are in use by which machine, etc...
Message 7 of 12
dgorsman
Three letters for you: JTB.  Excellent license reporting tools.
Message 8 of 12
TravisNave
If the adskflex.exe is already running on that server (because it is configured with the LMTOOLS service) then it is likely a conflict issue.  You will want to at least stop the service and then restart the lmadmin service.  Let me know if you still have an issue.  The real-time reporting (and configured alerting) is definitely a nice feature to have and probably more geared for what you are looking for.
Autodesk Forums:
Message 9 of 12
Hello!
The download link points to the 32-bit version of lmadmin.
We're running the 64-bit version on our license-servers but we're still on version 11.11.
Does somebody have a download link to the 64-bit version 11.12 of lmadmin?
It seems quite hard to find...
Regards!
Stefan Johansson, Linnaeus University - Sweden.
Message 10 of 12
TravisNave
Technically you only need the 11.12 (or 11.7) version of adskflex.exe from
the regular FlexLM and you'll be set.
Autodesk Forums:
Message 11 of 12
I've been running adskflex under lmadmin 11.11 both 64-bit versions (or so I thought) under Windows Server 2008R2 and I've had issues stopping the adskflex vendor daemon using lmadmins web-interface since updating to adskflex 11.12 (Autodesk Building Suite 2016 for academic).
Yesterday I managed to find links to both 64-bit and 32-bit versions of lmadmin version 11.12 at: https://www.transcat-plm.com/support/downloads/flexnet-publisher.html  When I compare the downloaded lmadmin-files with the command: FC /B they seem to be identical.  SysInternals Process Exporer running on the server reports lmadmin.exe as a 32-bit executable and adskflex.exe as 64-bit which I didn't think would work...
I've updated to lmadmin 11.12 on the license server but I've yet to try stopping the adskflex vendor daemon from the lmadmin web-interface.
MATLAB MLM-daemon 11.13 responds to shutdown-requests properly though.
Kind regards!
Stefan
Message 12 of 12
TravisNave
Right. You'd need the 32-bit adskflex if you are using 32-bit lmadmin.
Autodesk Forums:
Administrator Productivity
