Kindly clarify the following:-
Can an image-raster map be opened in Create Menu- Plane; insert a contour image map, then use the sculpt tools to carve the map according to the contour levels etc. into a 3D map to use it further to improvise technically. Personally you may co-ord vide email: unseencloud@yahoo.co.uk
