Hello there,
This is Ramesh Jayaraman from Prasad Corp, India. I want to share the roto mask from Flame to Lustre grading suite,
Can Someone help me on this?
Since I don't find any dedicated forum for the Lustre I'm posting this here. And if it is not appropriate, apologize.
Your help on this is very much appreciated.
Ramesh Jayaraman
Hi Yann,
Thanks for the reply. Pls do find below query from one of my client, and
Am I sensible to request you for the solution?
Is it possible to execute roto work to create power window style mattes
via any package, then be able to export that roto as gMask spline data and
import that gMask spline data into Lustre, so that the spline data is
"live" and can be manipulated by a colorist, the same as working with a
power window created directly in Lustre?
Much appreciated,
Ramesh Jayaraman
Hi Ramesh,
You can refer to the link below for the complete documentation:
http://help.autodesk.com/view/FLAME_P/2016/ENU/?guid=GUID-0E9CBCD8-D694-4745-9F12-4930B437CA58
Note that this applies to raw gmaks (not including animation or tracking data).
Also, be aware that the path mentioned in the documentation is incorrect:
/usr/autodesk/<version number>/settings/geompresets directory
should be
/usr/autodesk/<version number>/presets/geompresets directory
Please let us know if you have any further questions,
Yann
