Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
Roto Mask help
3 REPLIES 3
Pixelove
382 Views, 3 Replies
Roto Mask help
Hello there,
This is Ramesh Jayaraman from Prasad Corp, India.  I want to share the roto mask from Flame to Lustre grading suite,
Can Someone help me on this?
Since I don't find any dedicated forum for the Lustre I'm posting this here.  And if it is not appropriate, apologize.
Your help on this is very much appreciated.
Ramesh Jayaraman
3 REPLIES 3
yann.laforest
in reply to: Pixelove
Hi Ramesh,
There is no way to share animated gmasks between Flame and Lustre.
Such of a collaborative feature does not exist.
You can only share raw gmasks between Flame and Lustre at the moment. This excludes the animation data.
To do so, please follow the steps below:
Loading Garbage Mask Setups from Autodesk Applications
You can load garbage mask setups created with other Autodesk products (Flame, Flame Assist and Flare) to use as geometries in Lustre.
To import a garbage mask setup, you must export it from the applicable
Autodesk product as a raw setup file, and then save it to the Lustre program directory. You can then load
the garbage mask setup to the current secondary for use as a geometry.
NOTE You must create the geompresets directory manually to store your raw setup files. However, if you have
created a preset, the geompresets directory is automatically generated.
To load a garbage mask setup:
1 Export a raw setup file from the applicable Autodesk product.
2 Do one of the following:
?? If using the Linux version of Lustre, store the raw setup file in the /usr/autodesk/
number>/settings/geompresets directory.
3 Click Presets to display the Presets list.
4 Expand Gmasks raw import, and then select the raw setup file.
5 Click OK to load the garbage mask setup.
The geometry appears in the Player.
Please let me know if you have any other questions,
Yann
Yann
Yann Laforest
Feedback Community Manager
Autodesk Canada Co. 10 rue Duke Street
Montr??al (Qu??bec) Canada H3C 2L7
Direct 514 954-7241
[Description: Description: Description: Description: Description: autodesk-logo-rgb-color-logo-black-text-small]
Yann Laforest
Program Manager Data Analytics - Autodesk EMS
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
Pixelove
in reply to: yann.laforest
Hi Yann,
Thanks for the reply. Pls do find below query from one of my client, and
Am I sensible to request you for the solution?
Is it possible to execute roto work to create power window style mattes
via any package, then be able to export that roto as gMask spline data and
import that gMask spline data into Lustre, so that the spline data is
"live" and can be manipulated by a colorist, the same as working with a
power window created directly in Lustre?
Much appreciated,
Ramesh Jayaraman
yann.laforest
Hi Ramesh,
You can refer to the link below for the complete documentation:
http://help.autodesk.com/view/FLAME_P/2016/ENU/?guid=GUID-0E9CBCD8-D694-4745-9F12-4930B437CA58
Note that this applies to raw gmaks (not including animation or tracking data).
Also, be aware that the path mentioned in the documentation is incorrect:
/usr/autodesk/<version number>/settings/geompresets directory
should be
/usr/autodesk/<version number>/presets/geompresets directory
Please let us know if you have any further questions,
Yann
Yann Laforest
10 rue Duke Street
