Layout not initialize is basically a sheet in AutoCAD that has not been
accessed when it's created. For example, when creating a new DWG, there is
the Model, Layout1 and Layout 2. If you draw in the model and in Layout 1,
but never access Layout 2, then Layout 2 is not initialized. Once you work
with Layout 2, it will be initialized. I don't know if you can convert a
sheet back to not initialized once it's been finalized. You may want to
post that question to the AutoCAD newsgroup.
"Jimmy Bergmark" wrote in message
news:4859530@discussion.autodesk.com...
May I ask how a DWG author can set a layout to status "layout not
initialized" if he don't want it publicated?
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) -
http://www.jtbworld.com/?/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2005 and 2006
http://www.jtbworld.com/autocad2005.htm
http://www.jtbworld.com/autocad2006.htm
"Anne Marie Jackson Autodesk Tech Pubs"
wrote in message
news:4859377@discussion.autodesk.com...
From the Help, under Publishing or Layout not initialized:
No errors: Only layout sheets that say "No errors" in the status field can
be published
through the Publish dialog box.
Layout not initialized: A layout tab that says "layout not initialized" was
not intended
for publication by the DWG author.
To publish other sheets in the list, remove any layouts that show a status
of "layout
not initialized." See Remove Sheets below.
To create a DWF from a layout that is not initialized,
1. Remove the sheet from the list.
2. Plot it to the DWF6 ePlot.pc3 format.
3. Add the resulting DWF sheet back to the sheet set within DWF Composer.
(See the
DWF Composer help for composing a drawing set or adding drawings.)
See the DWG Viewer ReadMe for more information.
wrote in message news:4858750@discussion.autodesk.com...
When
trying to publish thru the DWG Viewer in from Composer 2 I get plot errors &
it says Layout Not Initialized. How could this be when I have already set up
the Page Setup Manager? I have never had this problem before?
any help?
