Comunidad
Civil 3D - Español
Comparta su conocimiento, haga preguntas y explore los temas populares de Civil 3D.
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Improve "BasicSideSlopeCutDitch" subassembly
0 RESPUESTAS 0
Responder
Mensaje 1 de 1
joantopo
235 Vistas, 0 Respuestas
In the stock subassemblies there is, "BasicSideSlopeCutDitch", but it could have more parameters.
Boolean input parameter (Yes/No)---  Ditch in Fill.  (now it is only for cut).
Material (pavement) on the ditch.
Mininum length of the ditch. (longitudinal).: For example, I don´t want  a ditch if it is less than 3 meters in the cut.
Sometimes, there is ditch in  the fill zones:
(the gray line is the outside ditch) and the green lines are the fill slope.
Moreover, when we will check (all) the stock subassemblies of Civil 3D in our own with SAC?
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
0 RESPUESTAS 0
Publicar en los foros
New events in the Spanish Community
