When bring a Revit model into 3DS Max Design 2015 versions as rvt or fbx the objects appear in the layers with RPC identifiers and a place holder in the relevant position of the image as an XYZ symbol or a blue cube. How do I get the RPC to display and render?
Solved by iadproductions. Go to Solution.
Hello and thank you for your forum posting. Can you provide a screen shot of what you are seeing? If I send you a private message would you be able to provide a REVIT model to test for you?
Thank you and best regards,
Jonathan Matthews
Autodesk Technical Support.
Our Screencast software can help you with the screen shot or creating a short video of what you are seeing and need help with.
Do you have the Archvision RPC Dashboard installed and then installed the plugin for 3ds Max ?
Thanks for the replay. Found out 3d MAX 2016 requires to install the plugin from the https://www.archvision.com/RPCPlugins manully. Also, learned 3d MAX 2016 allows .fbx from revit linked to MAX, but does not work work .rvt linked with MAX.
This is the same problem i am having with 2015 versions of Revit and 3DS MAX. Would appreciate any assistance
