3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to remove the annoying "edges appearance"
18 REPLIES 18
Message 1 of 19
1907 Views, 18 Replies
Hello guys.
In 3ds max 2016 when I add or remove an edge (for example, using the Swift Loop), the edge comes up slowly and appearing in 4-5 seconds.
Screen:
Click-to-create the swift loop: http://prntscr.com/78w2k5
After 3-4 seconds: http://prntscr.com/78w2og (the edges appear finally!)
It's pretty annoying. This doesn't happen, for example, in 3ds max 2015 where the edges comes up instantly.
It this option removable?
Thanks in advance!
18 REPLIES 18
Message 2 of 19
Up!
Message 3 of 19
Up!
Please, have you a solution?
Message 4 of 19
PROH
Hi. Could be a graphic driver issue. Have you tried to change driver to Nitrous Direct 3D 9.0 or Open GL?
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 5 of 19
in reply to: PROH
I use nitrous direct 3d 11 for 3ds max 2015 i've no problems... conversely, on 3ds max 2016 that strange thing happens.
Does it happen even on your pc?
Message 6 of 19
PROH
Just because you can use Nitrous Direct 3D 11 in Max2015, there's no guarantee that the same goes for Max2016. So please try to see what happens with another driver. That way we can see if this is a driver issue.
3dsMax 4.2 to 2018
Message 7 of 19
in reply to: PROH
Using other drivers, the software becomes really heavy... the best is the default one even if it's that strange problem.
Does that happen even for you? in 3ds max 2016 i mean
Message 8 of 19
PROH
I don't use 2016 yet. Did you test it with other drivers? If so, what happened with your edge problem?
3dsMax 4.2 to 2018
Message 9 of 19
in reply to: PROH
Other drivers are ok about that question. But about the rest, it sucks so much 'cause the program gets slow and heavy
Message 10 of 19
PROH
So it seems to be a driver issue for sure. Try updating your graphic card driver, and if that doesn't help, you may wait for the next driver version, and hope it's solved then. You could also try to install the previous driver version - sometimes that works better than the newest.
Hope it helps
3dsMax 4.2 to 2018
Message 11 of 19
in reply to: PROH
But it's so strange...
Does anyone of you have 3ds max 2016 to tell me if that happens also to him?
Message 12 of 19
up! I still can't find any solution... it's incredible <.<
Message 13 of 19
UP!
Message 14 of 19
peter.spence
I can confirm that I had this ghosting issue too.
Until I did this...
In the viewport, click the +
Configure Viewports...
Display Performance tab
Uncheck Improve Quality Progressively
See if that helps.
Kind regards,
Peter Spence
Putty Studios
Creatures & Visual Effects
www.PuttyStudios.com
Kind regards,
Peter Spence
Putty Studios
Characters & Visual Effects
Message 15 of 19
office
in reply to: peter.spence
I have exactly the same problem. If you follow peter.spence's solution it should solve the issue. I'm not sure why it happens though.
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
Message 16 of 19
Man, i love you!
Problem solved! THANKS!!!
Message 17 of 19
peter.spence
Glad to hear it worked for you too!
I just played about a bit and hit on that solution.
Kind regards,
Peter Spence
Putty Studios
Message 18 of 19
in reply to: PROH
Woah, glad there is actual option - though for such unobvious one autodesk should be beaten in the balls with a hedgehog. And few more additional times for adding that in the first place.
Message 19 of 19
in reply to: PROH
It isn't a drive issue.
I've had this happen on machines at school, and 2 very different machines at home.
The edge loops take 4-5 seconds to fade in. It is indeed annoying!
This did not happen in 2015 version - same machines.
