3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
RPC as blue boxes from Revit
4 REPLIES 4
dbarringer
650 Views, 4 Replies
When bring a Revit model into 3DS Max Design 2015 versions as rvt or fbx the objects appear in the layers with RPC identifiers and a place holder in the relevant position of the image as an XYZ symbol or a blue cube. How do I get the RPC to display and render?
Tags (3)
4 REPLIES 4
Hello and thank you for your forum posting.  Can you provide a screen shot of what you are seeing?  If I send you a private message would you be able to provide a REVIT model to test for you?
Thank you and best regards,
Jonathan Matthews
Autodesk Technical Support.
Our Screencast software can help you with the screen shot or creating a short video of what you are seeing and need help with.
iadproductions
in reply to: dbarringer
Do you have the Archvision RPC Dashboard installed and then installed the plugin for 3ds Max ?
Mastering Autodesk 3ds Max 2013
http://www.amazon.com/Mastering-Autodesk-3ds-Max-2013/dp/1118129717/ref=zg_bs_4135_2
dbarringer
in reply to: iadproductions
Thanks for the replay. Found out 3d MAX 2016 requires to install the plugin from the https://www.archvision.com/RPCPlugins manully. Also, learned 3d MAX 2016 allows .fbx from revit linked to MAX, but does not work work .rvt linked with MAX.
This is the same problem i am having with 2015 versions of Revit and 3DS MAX.  Would appreciate any assistance
