Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
Motion Trail
17 REPLIES 17
Message 1 of 18
1448 Views, 17 Replies
Motion Trail
Hi.
I made a MotionTrail Tool.
You can see and edit trails of animated objects.
If you'd like, try it.
how to use
1. install addon.
2. register a shortcut key or a script button.
3. activate the tool, and select an animated object.
motiontrail.zip
17 REPLIES 17
Message 2 of 18
tried to install in softimage 2013 sp1 x64bit and in the plugin manager the dll is marked as red.
tried to assign a custom hotkey in the keyboard mapping panel but i cant find it at all.
something is wrong? would like to try it.
thanks
Message 3 of 18
goooood
Message 4 of 18
> langdon
Thank you for the information.
Do you use other "StartAnimation" or "StopAnimation" plugins?
I use these names as Event Plugins in this plugin.
So, if you already use these names, my plugin will be error.
I changed my event names into other unique names.
If you use these names, please try version 1.1. You can install.
But if you don't, I have no idea...
Could you tell me Script Editor's Error Log?
I think you can see logs, when you try to install addon.
anyway thanks.
> svsh
Thank you!
motiontrail_v1.1.zip
Message 5 of 18
Thank you a lot.
I managed to get it to work, i select the animated object and start the MotionTrail the trail appears and i can select the points but how can i move them? No handles will appear, if i swtich to move tool i lose the motion trail.
I cant move those points.
edit: nevermind i had to reboot softimage, everything works now. Thanks a lot!
Message 6 of 18
piotrekmarczak
Hi taro,
can you upload it to si-community.com? this forum is dead
good work!
Message 7 of 18
どうもありがとうございます!!
Message 8 of 18
> langdon
I'm relieved to hear that.
Maybe you know this.
But I explain for others.
This plugin doesn't have handle like manipulator.
You can pick points immediately.
> origin
Thank you.
I want to do it, but I can't register si-community.com...
oh, but somone posted it instead of me. thanks!
> Procedural
どういたしまして!
Message 9 of 18
Leendert68
@taro - Did you already try logging in at the si-community? An account named "taro" has already been registered and activated there. You probably didn't get any activation notification, but, sadly, that's sort a known bug in "our" forum software...
PS - If you still experience difficulties logging in, please send me a Private Message here, so we can try to sort this out!
Message 10 of 18
in reply to: Leendert68
Thank you, Hirazi Blue!
I could enter si-community!
It was my fault.
Pleae look at the reason in si-community.
I'm embarrassed.
Message 11 of 18
Leendert68
Don't worry about it, these things happen. I'm just glad it "works" now.
Message 12 of 18
Can`t find it.
Will be nice add to camera view menu
Message 13 of 18
Leendert68
Did you create a shortcut key as described in the readme file?
( command name is "MotionTrail", it is in "Custom Script Commands" group. )
Message 14 of 18
have not this command
Message 15 of 18
Leendert68
Did you install the correct addon for your architecture:
MotionTrail32_v1.2.xsiaddon for a 32 bits Softimage/Windows
or
MotionTrail64_v1.2.xsiaddon for a 64 bits Softimage/Windows?
Message 16 of 18
Someone gave me an email, and he could install this addon after he installed Microsoft C ++ 2010. (maybe, visual C++ )
I'm not sure if this tool needs it. but if you can't install it yet, you can try.
and this addon used ToolContext, so you can install it softimage 2012 or lator .
Message 17 of 18
thanks
works fine
MotionTrail64_v1.1 not 1.2
Message 18 of 18
FalconCrest
Thank you a lot.
I rebooted three times and I can't see MotionTrail anywhere in the U.I, never mind seeing it in the Keyboard configurator panel. I installed the x64 bit version, and, well, no go.
