Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
mel's evalDeferred
3 REPLIES 3
wangr
539 Views, 3 Replies
mel's evalDeferred
isn't there any equivalent function/command in XSI SDK act as evalDeferred in Maya Mel? please...
thanks,
Ruiying
3 REPLIES 3
hbahnassi
in reply to: wangr
If you are using Jscript in XSI, you can use:
eval("// Your Code as String")
If the script is in another file, you need to read it first then evaluate it in your script.
Here's an example:
var s_scriptFile = "C:\\ExternalScript.js";
var o_fso = new ActiveXObject("Scripting.FileSystemObject");
if (!o_fso.FileExists(s_scriptFile))
LogMessage(s_scriptFile + " File not found!", siError);
else
var o_file = o_fso.OpenTextFile(s_scriptFile, 1)
eval(o_file.ReadAll());
o_file.Close();
Homam
wangr
in reply to: hbahnassi
Thank you Homamo!
hbahnassi
in reply to: wangr
Or better solution:
Application.ExecuteScript( FileName, , , );
Reference:
http://download.autodesk.com/global/docs/softimage2013/en_us/sdkguide/index.html?url=si_om/Model.Fin...
Homam
