hello. I was trying to create an empty plugin in C#. After building the project in Visual C# Express 2005 and updating it inside XSI, I got the following error:
ERROR : 2424 - XSI failed to load a .NET plug-in. This error happens because the plug-in may have been compiled with a different version of XSI. Recompile the plug-in with the current version of XSI to fix the problem.
// <Plug-in: C:\Users\user\Documents\XSI_Projects\scripts\burtoDnm\Application\Plugins\xxx.dll>
However, I am using only one version of XSI through out the process. I also did create a add-on workgroup and placed the files as described in the SDK help.
any help is appreciated, thanks
