Wiretap (Read Only)
Wiretap Webserver Problem
5 REPLIES 5
Steffen.Knauf
1514 Views, 5 Replies
i installed the Wiretap Web Server (2007.1.1038) on linux server.
If i want to create a projekt, i get a xml error:
XML-Verarbeitungsfehler: Nicht übereinstimmendes Tag. Erwartet: .
Adresse: http://10.1.1.122/cgi-bin/wiretap_cgi?&operation=createNode&server=10.1.1.2:7549&nodeId=/stonefs&path=/stonefs,stonefs&nodeType=PROJECT&mode=edit
All other functions works fine.
greets
Steffen
5 REPLIES 5
labuted
in reply to: Steffen.Knauf
Hi Steffen,
There may be some kind of "normal" Project creation error (e.g. volume is locked). I'm surprised the web server doesn't show the error somewhere. I suggest you check the Apache web logs and/or use one of the WT command-line tools to simulate.
What version of IFFFS are you using?
Dan
hi Dan,
there ist no error Message in the Apache Log.
Here are some parts of the /usr/discreet/sw/log/ifffsWiretapServer.log:
4134237888 CoMsgLogger.cpp:105 12/01/08:10:07:23.985 Command line: './ifffsWiretapServer'
4134237888 CoSmartheapUtils.C:371 12/01/08:10:07:23.985 Using SmartHeap version 7.1.0
4134190000 CoThreadPthread.C:189 12/01/08:10:07:23.986 Registered thread 'Logger' [ -160777296 ]
4134237888 sw_wiretapd.C:344 12/01/08:10:07:23.992 Starting WireTap Server daemon version 2007.0.3 (ProductSW30_1058).
4134237888 sw_wiretapd.C:347 12/01/08:10:07:23.992 Wiretap config file: /usr/discreet/sw/cfg/wiretapd.cfg
4134237888 sw_wiretapd.C:359 12/01/08:10:07:23.992 Initializing WireTap base services.
[user] 4134237888 ifffsWTNodeServerPlugIn.C:42 12/01/08:10:07:23.992 Initializing IFFFS WireTap Node Server Plug-In version 2007.0.SP5 (Product_3061).
[notice] 4134237888 swClient.C:204 12/01/08:10:07:23.992 Using Stone+Wire API 2007.0.3 [ProductSW30_1058] (32 bits)
The last lines:
[debug] 4134237888 WireTapNodeServerAPI.C:269 12/01/08:10:22:55.023 Calling getNodeType( /stonefs/users ).
[debug] 4134237888 WireTapNodeServerAPI.C:299 12/01/08:10:22:55.023 Calling getNodeTypeStr( /stonefs/users ).
[debug] 4134237888 WireTapNodeServerAPI.C:697 12/01/08:10:22:55.023 Calling getMetaData( /stonefs, XML, ProjectCfgTemplateList, 0 ).
Deleting,Editing Projekts works fine. Create new libraries works fine, too.
How can i simulate it on the commandline?
greets
Steffen
labuted
Have a look at the SDK guide.
After reinstalling the rpm packages all works fine 😉
greets
Steffen
labuted
Good to hear.
