Wiretap
Valued Contributor
0 Kudos
Post 1 of 4
wiretap bandwidth throttling.
201 Views, 3 Replies
08-23-2007 12:51 PM
When we are retrieving material from Wiretap we are able to saturate the GigE pipe. but when sending material into Wiretap it caps around 30 MB/sec even when trying with a variety of strong client machines. So I am wondering if there is a server setting that is limiting to this value?
Alan Message was edited by: alatteri
Distinguished Contributor
0 Kudos
Post 2 of 4
Re: wiretap bandwidth throttling.
08-23-2007 03:18 PM in reply to: alatteri
No, there's no such setting.
30 MB/sec happens to be the maximum thoughput you would get from a typical IDE drive. Are you reading from disk to provide the source data to send to the server?
Aside, there are many potential reasons for performance drops.
Valued Contributor
0 Kudos
Post 3 of 4
08-23-2007 03:45 PM in reply to: alatteri
Well we are reading from disk, but most of the content people send with our stuff is compressed QTs, so really the input is much smaller than 30 MB/sec, but goes over the GigE as uncompressed RGB.
Does that reservation setting in sw_config have any affect on Wiretap?
0 Kudos
Post 4 of 4
08-23-2007 04:05 PM in reply to: alatteri
The sw_config setting does absolutely nothing.
I suggest you run wieap_client_tool with the -c parameter to read a clip and report the performance numbers. I think using the -d (destination) may also report write values as well.
This will give us a baseline for read/write performance on the system in question. Message was edited by: dlabute
Post to the Community
New Post
