Wiretap (Read Only)
Having trouble adding wav audio to a clip
0 REPLIES 0
Message 1 of 1
andyjafa
846 Views, 0 Replies
When adding audio to a clip using the command line tools (2013.2/wiretap_create_audio) I get the following error:
'Cannot create audio node: The given audio format is not consistent with the given audio depth'
My wav is pretty standard - 48k @ 24bit - I specify these in the command, but it still gives the same result, I have tried a lot of options but nothing seems to work, any suggestions?
Cheers,
Andrew
0 REPLIES 0
