How about a way to group selected clips in the Clip Editor, (such as 4 wheels) so you don't need to individually adjust them?
Solved by marcus_fritzen. Go to Solution.
actually there is already a way to do what you suggest. Simply create a new sub-clip and move all block you want into it. To do so, right click on the desired parent clip in the list view and choose 'New Clip'. Now move all the blocks e.g. for the 4 wheels into the new sub-clip. Select the parent clip again and now you can modify all the blocks by simply modifying the new sub-clip.
We could think about adding such an option to the context menu of the graphical view like 'Create New Clip From Selection'...
/Marcus
