Hey,
Ive come across a problem in the camera editor window when changing the roll on the current active camera (with the wheel or manually), the value changes as you move the wheel but nothing happens in the viewport. When you then click in the viewport the camera roll value resets back to 0.
Does anyone know how to sort this issue?
Solved by richardlevene. Go to Solution.
It is a bug and the developers know about it and I have been told it will be fixed in the next service pack
