VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Texture filtering
8 REPLIES 8
Message 1 of 9
joulsoun
1880 Views, 8 Replies
Texture filtering
Is it possible to switch off texture filtering for ray tracing? I'm using super-detailed normal maps which look great up close, but at a distance the texture filtering makes the materials shiny as opposed to the roughness that the normal map would indicate:
Scaled down from 4K                                                       Rendered directly at this resolution
Scaled down from 4KActual resolution
The behaviour is the same for non-raytracing, but I guess the fix isn't as obvious there as just switching off texture filtering.
Cheers,
Jens
8 REPLIES 8
Message 2 of 9
florian.dyck
in reply to: joulsoun
Hi Jens, did you change the texture's filter value / anisotropy in the material?
Another thing you can try: to uncheck "compress textures" in the Common section of material editor.
Message 3 of 9
joulsoun
in reply to: florian.dyck
Thanks Florian!
Compress Textures seem to be switched off.
Setting Anisotropy to 0 sure made things better, but it still seems like some kind of texture filtering is going on:
4K        320x240
4K                                           160 x 120
So the problem remains, but the scale at which it occurs is pushed further. There's no magic preference setting to completely switch off texture filtering? Rendering at insane resolution and downscaling only solves the problem to a certain scale unfortunately, so I don't consider it the perfect workaround.
Thanks for the quick feedback,
Jens
Message 4 of 9
florian.dyck
I don't know of a magic switch to turn filtering off 😞 I just looked in render settings and options and tried to find similar settings as I would expect in Maya, but there aren't.
file:///C:/Program%20Files/Autodesk/VREDPro-7.01/doc/vrRenderSettings-module.html#setRaytracingStillFrameTextureSharpness
there is a Python command for vrRenderSettings, I haven't tried if it sets the same settings as the anisotropy value.
setRaytracingStillFrameTextureSharpness(sharpness)
Sets the sharpness factor for texture sampling (advanced feature). WARNING: Changing this settings may lead to rendering artifacts!
Parameters: sharpness - The sharpness factor.
           (type=float)
Maybe try other pixel filters for rendering (Mitchell Netravali 2.2 etc.)
Or try saving your texture in DDS format including mipmaps.
Also I am just a standard VRED user and I guess the development team from Autodesk knows some better answers.
Message 5 of 9
VRED tries to avoid moire artefacts and excessive noise so the bump maps will always be filtered.
On way to control the filtering a bit is by using the
This adjusts the area to do the filtering and it will therefore keep the bumps over a further distance.
However, assuming that you are using raytracing, I would recommend to use a displacement map instead. The will not get filtered and if the displacement height is not to huge it should still give you a reasonable performance. Just make sure that your basemesh is not too coarse since this will slow down the displacement calculation.
Michael Nikelsky
Sr. Principal Engineer
Message 6 of 9
joulsoun
in reply to: michael_nikelsky
Thanks Florian and Michael,
I don't have a problem in battling aliasing and noise with brute force sampling, I do have a problem when my nice rough surface becomes shiny, I can't fix that with higher sampling 😞
The setRaytracingStillFrameTextureSharpness looks interesting, and the tip about displacement too! Let's just hope my RAM can take it... But that would get me bump self-shadowing as well which is cool.
I'm off on vacation, so I won't be able to try this for a few weeks, but thanks a lot for the quick awesome help!
Jens
Message 7 of 9
michael_nikelsky
Displacement mapping in VRED doesn´t require much RAM. Basicly the accelleration structure gets a littlebit deeper and your texture will be RGB with mipmaps, that´s pretty much it. We don´t create any triangles so you can pretty much put it on everything and won´t get into any trouble memory wise. Only thing to keep in mind is, since we don´t create triangles, the base mesh shouldn´t be too coarse, otherwise the rendering will take much longer. But if you have car with a good tessellation you should be able to just apply a displacement map to everything and be fine.
Michael Nikelsky
Message 8 of 9
joulsoun
setRaytracingStillFrameTextureSharpness together with setRaytracingInteractiveTextureSharpness did wonders for me, thanks!
Displacement mapping also seems to work great, although I'm a bit surprised that it does, as you seemed to mention that the lookup is mipmapped, which is texture filtering in my book. I'll have to experiment more with it though, it looked awesome.
Message 9 of 9
michael_nikelsky
good to hear 🙂
Displacement mapping only uses bilinear filtering, not mipmapping. The mipmap levels are for some internal precalculations we need to do to accellerate the displacement mapping.
Kind regards
Michael
Michael Nikelsky
