Hello-
I am using Vred Design 2014 SR1-SP8.
I am trying to export parts from my Vred file into 3ds Max Design 2014 to modify, then bring back into Vred.
I have tried to export the parts as an fbx as well as an fbx scene. The parts have been optimized in Vred prior to export.
When I import the fbx into Max, the fbx import interface says the File Version is 7.1.0 and the File Creator is Fbx version 2011.3.
When I click 'Import', Max crashes.
How can I verify the fbx version in Vred?
Any suggestions on what Fbx version to use with Vred Design 2014 and Max Design 2014?
Thanks-
Joel
The version you mentioned is correct, VRED uses Fbx 2011.3 at the moment.
