I'm getting this python error in version SR1-SP2 but not in SR1-SP1.
Solved by michael_nikelsky. Go to Solution.
the executePython command now has an additional bool parameter to control sync behaviour between multiple vred instances. Looks like this broke the old version, we will look into that.
As a workaround you can call
executePython('enableHeadlight(true)', true)
Kind regards
Michael
You´re welcome.
But out of curiosity: Why would you actually use the "executePython" command? Usually you can just call the command inside directly.
Kind regards
Michael
I only used that as a simplified example, the problem occurs in another more complicated script where "executePython" is required.
