VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
executePython error in version SR1-SP2
4 REPLIES 4
dlincol1
509 Views, 4 Replies
I'm getting this python error in version SR1-SP2 but not in SR1-SP1.
Dan
Tags (1)
4 REPLIES 4
michael_nikelsky
in reply to: dlincol1
the executePython command now has an additional bool parameter to control sync behaviour between multiple vred instances. Looks like this broke the old version, we will look into that.
As a workaround you can call
executePython('enableHeadlight(true)', true)
 Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
dlincol1
in reply to: michael_nikelsky
Michael, That works for me, thank you!
Dan
michael_nikelsky
You´re welcome.
But out of curiosity: Why would you actually use the "executePython" command? Usually you can just call the command inside directly.
Kind regards
Michael
Michael Nikelsky
dlincol1
I only used that as a simplified example, the problem occurs in another more complicated script where "executePython" is required.
Dan
