Is there a way to rotate decals a precise amount (e.g. 45 or 90 degrees)?
Solved by michael_nikelsky. Go to Solution.
I assume you are using the material based projections? There is a Rotate-Parameter for every texture where you can type in exact values.
Kind regards
Michael
