does anyone know how to change the camera transformation sensitivity in VRED? When I focus a whole object (car) in my scene the "pan" sensitivity is ok, slow. But when I focus a very small object, a screw for example, the panning gets very fast and even if I move the mouse only a bit the car is disappearing out of my render view immediately. I don't find any attribute in the camera editor, but I would like to keep the speed of the movement at a certain value.
I experience same issue. Would love to know how to control it or if not possible, get it fixed.
you need to adjust the clipping plane of the camera. Usually the clipping plane should be around the dimensions of the currently focused obejct.
Usually, when you press "f" for focus, the clipping plane should adjust automatically.
hope that helps
-Alex
the panning speed is related to the distance of the camera to the object on which you started panning with the middle mouse button.
So, if you start panning with the cursor positioned above the screw, the camera shouldn't move too fast in relation to the screw. If you start panning with the cursor above an object that is far away from the screw, your camera will move quite fast in relation to the screw.
Best regards
Sinje
Thank you Sinje,
I try to keep that in mind although I think it will be quite hard to get accustomed to it.
