I already install Desktop Radiance 2.0 following the steps mentioned in Autodesk Community Forum.
I' m trying to run a clear sky illumination model from Ecotect Analysis 2011 to Radiance. Everything looks working even i checked the step 8-9 in the wizard and the Radiance installation looks fine. I can get the image viewer and the black panel but the rendered image woudn't appear in the inside image box. And in the black panel i see RAD: error filtering view c1.
I have attached the screen shots for details ( test error).
In the other side, i test with opening the Radiance Control panel but when i render i find different message in the black panel than the last one and also the rendered image wouldn't appear in the image box.
i atteched the screen shot for this one ( test 2 error) .
Could you please help me to sort this out?
Thank you.
