Visualization
New Member
gearworks
Message 1 of 4 (507 Views)
circle rendering help
507 Views, 3 Replies
11-18-2011 07:52 PM
I could really use some help with this.
I’ve been using AutoCAD for about eight years now for architectural support in 2D. Lately drawing models for my smaller parts and rendering really helps to get the message across. Problem is rendering. I can never remove the segmenting of arcs and circles even in the highest of setting. Does AutoCAD have fundamental problems with rendering solids? I’ve used 3rd party programs for rendering also with the same results. I must be missing something.
Example of my setting:
Viewres = 20000
Facetres= 10
Whiparc = 1
segments in a polyline curve = 30000
attached are samples of segmented renders.
Thanks in advance.
New Member
jo_cescobar08
Message 2 of 4 (442 Views)
Re: circle rendering help
01-31-2012 04:55 PM in reply to: gearworks
hi, is a problem with your autocad, here si attached an example. The resolution is Medium.
New Member
mspenser
Message 3 of 4 (388 Views)
04-26-2012 09:56 AM in reply to: jo_cescobar08
It should be your autocad problem,  agree.
Active Contributor
dlipscombe
Message 4 of 4 (348 Views)
06-13-2012 12:32 AM in reply to: gearworks
Have you checked your graphics card is up to the job??
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
