AutoCAD Forum
Arrows doesn't appear in my Auto Cad
3 REPLIES 3
leosueiro123
744 Views, 3 Replies
Look this print:aaa.png
Can somebody help me?
Sorry if my english is not very clear.
3 REPLIES 3
Bob_Zurunkle
in reply to: leosueiro123
Ummmm are you using annotation objects? If so, what is your CANNOSCALE set to?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Anthonius
It could also be your "DIMSCALE".
What is the actual length of the item you're trying to dimension?
AutoCAD 2014 64 bit
Revit 2016 64 bit
Windows 7
Have a good time, all the time.
nestly2
I believe the arrows and text are there, the dimension scale is just too small for the size of the object.   I would consider using an Annotative dimensions so you don't need to manually assign dimension scales.
”Boost
