Hi there.
When I discovered the Environment setting and particularly the fog effect, it took some time to exercise, but the results were very strange: the fog rendered from gray to black, whatever color was assigned to it. Until I changed the lighting units to Generic. Now the fog was OK! The book "Lighting in AutoCAD", "AutoCAD 2014 Rendering - Revealed!" and some others also heavily recommended to use International system in every possible situation, but I found nowhere any description of this effect with fog. Now I have a question: should Generic system always be used when working with exteriors? Or only when fog is needed? IsnĀ“t there some contradiction between these recommendations? Or is there some trick to bypass this behavior?
Jaak
Tallinn, Estonia
