Z axis can't to zero.
bad drawing. Z axis can't to zero.
I use command "FLATTEN" can't reset Z axis to zero. I use LISP ,but it's too.
;;vla
;;(HH:vlaZto0 (ssget))
(defun HH:vlaZto0 (ss / E N OBJ P1 P2)
  (defun MoveOne (e)
    (setq obj (vlax-ename->vla-object e))
    (vla-move obj p1 p2)
    (vla-move obj p2 p1)
  (setq p1 (vlax-3d-point '(0 0 0)))
  (setq p2 (vlax-3d-point '(0 0 1000e99)))
  (cond
    ((equal (type ss) 'ENAME) (MoveOne ss))
    ((equal (type ss) 'PICKSET)
     (repeat (setq n (sslength ss))
       (MoveOne (ssname ss (setq n (1- n))))
;;DXF
;;(XX:LeftPick:LineZto0Ent (car(entsel)))
(defun XX:LeftPick:LineZto0Ent (ss)
  (defun MoveOne (e)
    (entmod
      (mapcar
'(lambda (X)
    (cond
      ((or (equal (car x) 11) (equal (car x) 10)) (list (car x) (cadr x) (caddr x)))
      (T x)
(entget e)
  (cond
any routine or any tools can solve this problem ?
DWG file in attachments.
3wood
You can try attached CHZ20.vlx.
I also attached the result dwg here.
It doesn't work on Region objects though.
3wood
It doesn't hurt to get a free registration.
Hi 3wood.
can only chage the block ?
3wood
No, it changes all entities including block definitions except for a certain entity types such as region.
