Visual LISP, AutoLISP and General Customization
xref report
3 REPLIES 3
346 Views, 3 Replies
xref report
Has anybody got a lisp program to generate a xref report. I know about designcenter  and use it a lot but I would like to be able to send the report a text file. Unfortunately I do not not always use the latest Autocad versions and so would need it to work from versions from Autocad 2009.
Thanks in advance
3 REPLIES 3
3wood
You can try Reference Manager.
(Start->All programs->Autodesk->AutoCAD 2009->Reference Manager)
hmsilva
Thanks in advance
As a "demo"...
(defun c:demo (/ fn lst of)
  (vl-load-com)
  (vlax-For blk
	    (vla-Get-Blocks (vla-Get-ActiveDocument (vlax-Get-Acad-Object)))
    (if	(= (vla-Get-IsXref blk) :vlax-True)
      (setq lst (cons (vla-get-path blk) lst))
  (if lst
    (progn
      (setq fn (strcat (getvar 'DWGPREFIX)
		       (vl-filename-base (getvar 'DWGNAME))
		       " - XRefs.txt"
      (setq of (open fn "w"))
      (foreach l lst
	(write-line l of)
      (close of)
      (startapp "notepad" fn)
  (princ)
HTH
Henrique
BlackBox_
Here's one I wrote many, many moons ago:
(vl-load-com)
(defun c:BatchFindXref (/ *error* _WriteXrefData acApp acDocs oShell oFolder path dwgs
                        filePath dbxDoc file doc ok
  (princ "\rBATCHFINDEXREF ")
  (defun *error* (msg)
    (if file
      (close file)
    (if oShell
      (vlax-release-object oShell)
    (if dbxDoc
      (vlax-release-object dbxDoc)
    (cond ((not msg))                                                   ; Normal exit
          ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
          ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
    (princ)
  (defun _WriteXrefData (doc)
    (vlax-for x (vla-get-blocks doc)
      (if (= :vlax-true (vla-get-isxref x))
        (progn
          (or ok (setq ok T))
          (write-line
            (strcat dwg
                    (vla-get-name x)
                    ".dwg,"
                    (vla-get-path x)
            file
  (if
    (and
      (setq acApp (vlax-get-acad-object))
      (setq acDocs (vla-get-documents acApp))
      (setq oShell (vla-getinterfaceobject acApp "Shell.Application"))
      (setq oFolder (vlax-invoke
                      oShell
                      'BrowseForFolder
                      (vla-get-hwnd acApp)
                      "Select folder to search:"
                      0
                      (+ 1 64 256)
      (setq path (vlax-get-property
                   (vlax-get-property oFolder 'Self)
                   'Path
      (setq dwgs (vl-directory-files path "*.dwg" 1))
      (setq filePath
             (strcat
               (vl-filename-directory
                 (vl-filename-mktemp)
               "\\Batch Find Xref Report_"
               (menucmd
                 "M=$(edtime,$(getvar,date),YYYY-MO-DD)"
               ".csv"
      (princ "\nWorking, please wait...")
      (princ)
      (setq dbxDoc (vla-getinterfaceobject
                     acApp
                     (strcat "ObjectDBX.AxDbDocument."
                             (substr (getvar 'acadver) 1 2)
     (progn
       (setq file (open filePath "w"))
       (write-line "Directory Searched:" file)
       (write-line path file)
       (write-line "" file)
       (write-line "Host Drawing:,Reference Name:,Saved Path:" file)
       (foreach dwg dwgs
         (cond
           ((not
              (vl-catch-all-error-p
                (setq doc
                       (vl-catch-all-apply
                         'vla-item
                         (list (vla-get-documents acApp) dwg)
            (_WriteXrefData doc)
           ((not
                (vl-catch-all-apply
                  'vla-open
                  (list dbxDoc (strcat path "\\" dwg))
            (_WriteXrefData dbxDoc)
           ((write-line
              (strcat dwg ",Unable to open drawing. ")
              file
       (princ "Done.")
       (if ok
         (vlax-invoke oShell 'open filePath)
         (prompt "\n** No surfaces found ** ")
     (cond
       (filePath
        (prompt
          "\n** Unable to create \"ObjectDBX.AxDbDocument\" Object ** "
       (path (prompt "\n** No drawings found ** "))
       (oShell (prompt "\n** No folder selected ** "))
       (acDocs
        (prompt
          "\n** Unable to create \"Shell.Application\" Object ** "
  (*error* nil)
"How we think determines what we do, and what we do determines what we get."
”Boost
