Nope, I'm in 2002.
Again, it's in the "ActiveX and VBA Reference" which is a part of the
"Developer Documentation". Here's the page from that help document:
Determines if the given block is an XRef block.
See Also | Example
Signature
object.IsXRef
object
Block
The object or objects this property applies to.
IsXRef
Boolean; read-only
TRUE: The block is an XRef.
FALSE: The block is not an XRef.
Remarks
The IsXRef property works with the IsLayout property. If both properties are
FALSE, then the block is a simple block. If the IsXRef property is TRUE,
then the block is an external reference. If the IsLayout property is TRUE,
then the block contains all the geometry associated with a layout.
Jeff
"ECCAD" wrote in message
news:17527164.1080071273932.JavaMail.jive@jiveforum2...
> Jeff,
> I can't seem to find it in my 'help' files anywhere,,possibly
> something new in R2004 ?
> Bob
