Hi! I am trying to create a new sipmle command that would allow to draw an xline between two midpoints:
(defun c:xlm()(command "xline" "m2p" pause pause "m2p" pause pause))
For some reason it works just fine with the first midpoint, but not the other one. Any suggestions would be appreciated!
Solved by gpcattaneo. Go to Solution.
Hi Viktors,
perhaps something like this
(defun c:xlm ( / p1 p2 p3 p4)
(if (and (setq p1 (getpoint "\nFirst point of mid: "))
(setq p2 (getpoint "\nSecond point of mid: "))
(setq p3 (mapcar '* '(0.5 0.5 0.5) (mapcar '+ p1 p2)))
(setq p1 (getpoint p3 "\nFirst point of mid: "))
(setq p2 (getpoint p3 "\nSecond point of mid: "))
(setq p4 (mapcar '* '(0.5 0.5 0.5) (mapcar '+ p1 p2)))
);; and
(command "_.xline" "_NONE" p3 "_NONE" p4 "")
(princ)
HTH
Henrique
Hi! Thanks, this worked like a charm! I still don't get why my command didn´t work though...
This one works perfectly well as well and is really interesting... I believed that one has to use PAUSE for every click one wants to get from user. It seems though that it stands for every point that has to be defined for the XLINE command (which would be 2 points, but 4 clicks if using M2P modifier). Thanks!
If you're using this to draw an Xline halfway between and parallel to two parallel straight things, or to bisect the angle between two straight things under the right kinds of circumstances*, try the BI command in Bisector.lsp here. It gets you there by picking the two objects rather than four points. It works with virtually anything straight -- Lines, Polyline line segments, Multilines, straight-format Leaders, Xlines, Rays, linear elements of Dimensions, pieces of Hatch patterns [with snapping to them enabled in newer versions where that's optional], 3DFaces, 2D Solids, straight edges of 3D Solids and Regions, Traces, such things when they're parts of Blocks, and even unlikely things like the edges of Images and Viewports and Tolerance boxes. If you either miss or pick something that isn't straight, it asks again. If the two selected things are parallel, it draws an Xline halfway between them. If they're not, it draws one bisecting the angle between them.
It also works in older versions of AutoCAD that don't have the M2P Object-Snap mode available.
* I say "under the right kinds of circumstances" because there can be different results from the two approaches, mostly depending on whether the situation is symmetrical or not, as illustrated. In the four-point-pick approach, you would pick the four ends of the two red Lines [in the right order, of course]; in the BI command, you would pick the two red Lines once each, anywhere on them.
