Here's my version:
;;--------------------- aboveline ---------------------------------------
;; Purpose: given 2D points p1,p2,p3
;; determines if p3 lies above or below the line defined
;; by p1,p2
;; Needs: two points p1,p2 to determine the line
;; point p3 to test
;; fuzz to determine required proximity to line
;; Returns: 1 if p3 is above the line
;; 0 if on the line
;; -1 if below the line
;; nil if the line is vertical or p1,p2 are coincident
(defun aboveline (p1 p2 p3 fuzz / m ret y3 yprime)
(if (= (car p1) (car p2)) (setq ret nil)
(progn
(setq m (/ (- (cadr p2) (cadr p1)) (- (car p2) (car p1)))
yprime (+ (cadr p1) (* m (- (car p3) (car p1))))
y3 (cadr p3)
(cond ((equal y3 yprime fuzz) (setq ret 0))
((> y3 yprime) (setq ret 1))
((< y3 yprime) (setq ret -1))
);cond
);progn
);if
ret
);aboveline
;;--------------------- rightofline ---------------------------------------
;; determines if p3 lies right or left of the line defined
;; by p1,p2
;; point p3 to test
;; Returns: 1 if p3 is right of the line
;; 0 if on the line
;; -1 if left of the line
;; nil if the line is horizontal or p1,p2 are coincident
(defun rightofline (p1 p2 p3 fuzz / m ret x3 xprime)
(progn
xprime (+ (car p1) (/ (- (cadr p3) (cadr p1)) m))
x3 (car p3)
(cond ((equal x3 xprime fuzz) (setq ret 0))
((> x3 xprime) (setq ret 1))
((< x3 xprime) (setq ret -1))
);cond
);progn
);if
ret
);rightofline
