Visual LISP, AutoLISP and General Customization
Writing a file path to a *. txt file
4 REPLIES 4
The_Caddie
369 Views, 4 Replies
I have a file path im trying to capture in a text file however its not working and autocad is prompting back,
; error bad argument type: streamp nil
 Im assuming its because of the slashbacks but Im not sure..
Herse the code sofar...
(defun C:GO ()
(SETQ ACADLSP (findfile "acad.lsp"))
(setq f (open "C:\test.txt" "w"))
(write-line ACADLSP f)
(close f)
4 REPLIES 4
hmsilva
in reply to: The_Caddie
change
"C:\Test.txt"
to
"C:\\Test.txt""
Henrique
The_Caddie
in reply to: hmsilva
nope that aint it ( i noted that you accidentaly added an extra double quote) though still didnt work.
hmsilva
this works for me
(defun C:GO ()
  (setq f (open "C:\\test.txt" "w"))
  (close f)
dicra
Try to run autocad as administrator,
I was having the same problem, I could create file on "D:" , but could not on "C:".
I think that is your problem, because I think that you cannot create a file on "C:" if you don't run autocad as administrator.
”Boost
