I am running autocad 2011 for mac to design sails. I was given a autolisp file that will automate the majority of the process, but it uses a .dcl file to input all the numbers. Unfortunately .dcl files are not support with the Mac version and therefore I am looking for any solutions.
- Is there another way to input the information and therefore link the lsp file to something different?
- Is it easy to re-write the lisp file and input directly into that?
I am a newbie, but willing to put the hours in to learn... just dont know which direction to put those hours into. At the moment the time I am wasting researching how to make the .lsp program work, I could have hand drawn most of the sails anyway!
Any help would be greatly appreciated.
attach the lisp file(s), as well as the dcl file(s) if you have them, perhaps from there we can see what your working with and see if there is a simple solution.
Attached are the 2 files. Would be great if you can point me in the right direction.... if there is one.
@k57skye wrote:Attached are the 2 files. Would be great if you can point me in the right direction.... if there is one.
The only workaround i can think of is usign a third party prgram like OpenDCL I believe they developed one for MAC
But not being able to work with Mac versions, I'm not use it'll work for you.
Thanks for that... but guess what... I dont think OpenDCL runs on Mac either!! Any other suggestions? Sounds like that would ave been the way.
@k57skye wrote:
I am running autocad 2011 for mac............. .dcl files are not support with the Mac........ Is there another way to input the information and therefore link the lsp file to something different?
Took a quick look at your lsp/dcl and although it would be messy due to the numerous fields, you could eliminate the dialog and accept input at the command line, or re-write it so that it accepts input from an ASCII file perhaps...?
i guess that would be the most logical thing to do.
I could've sworn OpenDCL gave-in to numerous request from MAC users to enable their program to work on Acad Mac.
Anyhoo. sorry cant be of more help k57skye
Without a pre-load of values for all these variables,
someone must do some answering of getreals.
The DCL can avoid every single answer, if the values are preloaded,
but that does not appear to be done anyway.
Usually, most of the variable's values are pre-defined,
which can be doen with some more code; and
even written to a file for strorage instead of 'hard' codeing.
This version seems to work here, XP, and
does not have pre-defined values; AND
uses 0 instead of Nil to bypass some creations.
Stevor.... Not sure if this is exceptable forum behaviour... but I love you!!! Thank you so much! I dont really understand what you were saying, but it works perfect, and will save me literally hours of drawing.
If I could buy you some beers I would!
One final remaining question... is there anyway to undo an entry... If I put in an incorrect number, is it possible to go back to it? Anyway... this can easily be adjusted later, so doesn't really matter anyway..
Thank you so much once again!!!
If you want to go down that path:
(defun c:test (/ dsl _strnum _val item dat_) (defun _strnum (val tl / p) (repeat (- tl val) (setq p (strcat " " (if p p " ")))) p) (defun Show (lst / i) (setq i 0)(textscr) (foreach itm lst (princ (strcat "\n" (itoa (setq i (1+ i))) (if (< i 10) " " " ") (strcat (car itm) (_strnum (strlen (car itm)) 16)) (rtos (eval (read (cadr itm))) 2 2) ) ))(princ)) (setq _val (lambda (data) (set (read (cadr data)) (if (setq def (eval (read (cadr data)))) def (progn (initget 7) (getreal (strcat "\n" (car data) ": "))))))) (foreach Var (setq dsl '(("Baseline" "bl") ("Boomstraight" "bs") ("Boomheight" "bh") ("Topoffset" "to") ("Topoffposition" "tp") ("Batten1" "b1") ("Batten2" "b2") ("Batten3" "b3") ("Batten4" "b4") ("Batten5" "b5") ("Batten6" "b6") ("Batten7" "b7") ("Batten8" "b8") ("Bp1" "bp1")("Bp2" "bp2")("Bp3" "bp3") ("Bp4" "bp4")("Bp5" "bp5")("Bp6" "bp6") ("Bp7" "bp7")("Bp8" "bp8") ("Luff1" "l1") ("Luff2" "l2")("Luff3" "l3") ("Luff4" "l4")("Luff5" "l5")("Luff6" "l6") ("Ln1" "ln1")("Ln2" "ln2")("Ln3" "ln3") ("Ln4" "ln4")("Ln5" "ln5")("Ln6" "ln6") ) ) (_val Var)) (Show dsl) (while (setq item (getint "\nItem to change: ")) (if (< item 33)(progn (setq dat_ (nth (1- item) dsl)) (set (read (cadr (setq dat_ (nth (1- item) dsl)))) nil) (_val dat_)(Show dsl)) (print "Invalid Item nos: ")) ) (princ "\n<<<<<< Your Program Here >>>>>>>>:") (princ)
The code will not draw your lines, its just a demonstration
Try it
Not sure what you mean.
A simple way is to run the routine again,
and change the valuess of the variables,
and create a new sail.
Wiht so many vars, it is, as RKM said: messy.
So perhaps if there are ony few
that are likey need frequent revision,
then I, or we, would change the lsp to:
1. Option to bypass the entire var setting
once it is entered the first time, and then
provide a revision of the select vars.
2. Or, put the entire var setting outside
the main routine, eg, c:SAIL, as an 'exterior' routine;
and put the revision of a few vars inside the main.
The routine to set all the vars could be named c:SailV, etc.
3. Or, you could have several exterior routines
to change sets of vars.
The list format shown by Pbejse may be easier to visualize
each var, but takes a little longer to write code,
if you are trying it.
All that just for Varable settings.
Again, I would record the initial settings,
somewhere in the sail lisp code, or
in another file, like aSail.dat.
If this is the type of concern,
post a list of the values.
