Visual LISP, AutoLISP and General Customization
why don´t work this lips in autocad 2015?
3 REPLIES 3
andresep82
506 Views, 3 Replies
hello again,
I am trying the new version of autocad,and   this lips don´t work,why?
(vl-load-com)
(princ "\superficie_campo Cargada. Escribe \"sup\" para empezar..")
(defun c:sup ( / sele cod mens TotArea mens )
  (if (not (tblsearch "LAYER" "SUP_UTIL"))
    (command "_.-layer" "_make" "SUP_UTIL" "_color" 3 "" "")
 (if (not (tblsearch "LAYER" "TEXTO_HABITACIONES"))
    (command "_.-layer" "_make" "TEXTO_HABITACIONES" "_color" 7 "" "")
(setvar "fieldeval" 23)
(setvar "fielddisplay" 0)
(setvar "cmdecho" 0)
 (setq TotArea 0.0 )
(setvar 'clayer "TEXTO_HABITACIONES");change layer
 (prompt "\nSeleccione Polilineas para suma de Areas: ")
 (if
;(setq sele (ssget (list  '(0 . "LWPOLYLINE") )))
(setq sele (ssget    '( (0 . "LWPOLYLINE") (8 . "SUP_UTIL" ) )))
  (progn
   (vl-cmdf "_.UNDO" "_BE")
   (setq Cod 0 )
(initget 7)
(setq depend (getint "\n Numero inicial"))
 (mapcar (function (lambda (LwPol /  Centroid )
 (repeat
 (setq i (sslength sele))
        (setq e (ssname sele cod))
); end repeat
(setq Cod (1+ Cod))
(setq contorno e )
(setq objeto (vlax-ename->vla-object contorno)
Id (vla-get-objectID objeto)
super (strcat "%<\\AcObjProp.16.2 Object(%<\\_ObjId "(itoa Id)">%).Area \\f \"%lu2%pr2%ps%ds44\">%")
);END SETQ
    (setq Centroid (CentroidePol LwPol))
(setq inicial (getvar "attdia"))
(setvar "attdia" 0)
(setvar "ATTREQ" 1) ; fix possible attribute prompting issue
(setq dependencia (itoa depend))
   (command "_insert" "superficie" centroid "" "" "" dependencia super )
(setq depend ( 1+ depend))
(setvar "attdia" inicial)
(SsToList sele)
);c.mapcar
   (princ)
   (vl-cmdf "_UNDO" "_E")
  );c.prg
 );c.if
(setvar "cmdecho" 1)
 (prin1)
);c.defun
;;; Copyright ©2004 by draftteam software
;;; All rights reserved
;;; DRAFTTEAM PROVIDES THIS PROGRAM SOFTWARE "AS IS" AND WITH ALL
;;; FAULTS. DRAFTTEAM SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
;;; OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. DRAFTTEAM
;;; SOFTWARE DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL
;;; BE UNINTERRUPTED OR ERROR FREE.
;;; code: José Luis García
;;; http://www.draftteam.com
;;  dibuja un texto en la pantalla
(defun XDraw_Txt (al p cad col codh codv)
 (setq EntTxt
  (entmakex
   (list '(0 . "TEXT");'(8 . "ARQ_Areas_C_Cuadros")
     (cons 62 col)
          (cons 40 al)
          (cons 1 cad)
          '(50 . 0.0) '(41 . 1.0)
          (cons 7 (getvar "TEXTSTYLE"))
          (cons 72 codh)
          (cons 10 p)
          (cons 11 p)
          (cons 73 codv)
   );c.list
  );c.entmk
 );c.setq
);c.defun
;; conjunto de seleccion a lista de entidades
(defun SSToList (ss / ssl n)
 (if (and ss (= (type ss) 'PICKSET))
  (repeat (1+ (setq n (1- (sslength ss))))
   (setq ssl (cons (ssname ss n) ssl) n (1- n))
  );c.repeat
 ssl
);c.defun
(defun dxf (n eg) (cdr (assoc n eg)))
;lista de vertices de LWPOLYLINE
(defun GetVertPol (Pol / LPtspol)
 (mapcar 'cdr
  (vl-remove-if (function (lambda (x) (/= (car x) 10))) (entget Pol)))
;;;                    Centroide de LWPOLILINE
(defun CentroidePol (Poliline / lVertices Centroide)
  (setq lVertices (GetVertPol Poliline)
        Centroide (trans (CentroidLisPts lVertices) 0 1) )
) ;_ fin de defun
;;---------------------------- CentroidLisPts -----------------------------------
;; (Centroide de lista de puntos obtenidos de Polilinea)
(defun CentroidLisPts  (vlist /   segno n   ttl_area basex basey p1   p2 x1 x2 y1 y2 t_x t_y
         t_area t_xm t_ym r_x r_y r_area   r_xm r_ym Mx My)
 (setq vlist   (append vlist (list (car vlist)))
       segno   (1- (length vlist))
       n   0
       Ttl_Area   0.0
       Mx   0.0
       My   0.0
       basex   (car (nth 0 vlist))
       basey   (cadr (nth 0 vlist)))
 (repeat segno
  (setq   p1    (nth n vlist)
   p2    (nth (1+ n) vlist)
   x1    (car p1)
   y1    (cadr p1)
   x2    (car p2)
   y2    (cadr p2)
   t_x    (- (* (+ x2 x2 x1) 0.333333) basex)
   t_y    (- (* (+ y1 y1 y2) 0.333333) basey)
   t_area    (* (- y2 y1) (- x2 x1) 0.5)
   t_xm    (* t_area t_x)
   t_ym    (* t_area t_y)
   r_x    (- (/ (+ x1 x2) 2) basex)
   r_y    (- (/ (+ basey y1) 2) basey)
   r_area    (* (- x2 x1) (- y1 basey))
   r_xm    (* r_area r_x)
   r_ym    (* r_area r_y)
   Ttl_Area (+ Ttl_Area t_area r_area)
   Mx    (+ Mx t_xm r_xm)
   My    (+ My t_ym r_ym)
   n    (1+ n)) ;_ c. setq
  ) ;_ c. repeat
 (list (+ (/ Mx Ttl_Area) basex) (+ (/ My Ttl_Area) basey))) ;c. defun
(princ)
thanks¡¡¡¡¡
3 REPLIES 3
gpcattaneo
in reply to: andresep82
Converting (command) calls to (command-s) is recommended in AutoCAD 2015
hmsilva
@andresep82 wrote:
hello again,
Do you get any error message?
Henrique
andresep82
in reply to: gpcattaneo
yeah¡¡¡¡  Smiley Very Happy   thanks¡¡¡
”Boost
