Visual LISP, AutoLISP and General Customization
Why does vlax-get-property always return the color 256?
7 REPLIES 7
Message 1 of 8
cncah
613 Views, 7 Replies
I'm trying to use the vlax-get-property on several entities in a selection set and each entity is a different color, but when I use the:
(setq entColor (vlax-get-property oEnt 'Color))
 If keeps returning the color "256" on all entities in the selection set. Even though I know for a fact that they are all different colors. Is there a step I'm missing?
7 REPLIES 7
Message 2 of 8
dbroad
in reply to: cncah
256 means "bylayer".  So the objects may appear different colors because they are on different layers.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
cncah
in reply to: dbroad
So what would the proper way be of turning off "ByLayer" in lisp?
Message 4 of 8
cncah
in reply to: dbroad
Or a better question would be, how do I get the layer's color if the setting is "bylayer" instead of the 256?
Message 5 of 8
dgorsman
in reply to: cncah
First you need to test the entity color; if "fixed" then that is the color, if BYLAYER then you need to get the layer the entity is on and get the color of that layer, if BYBLOCK you need to check the parent block and get the color of that (which could in turn be BYLAYER).
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 6 of 8
Lee_Mac
in reply to: cncah
Below are example functions demonstrating how to obtain the colour of an entity or object (or the corresponding layer colour) using Vanilla AutoLISP or Visual LISP respectively:
Vanilla AutoLISP
(defun getentcolour ( ent / enx )
    (setq enx (entget ent))
    (cond
        (   (cdr (assoc 62 enx)))
        (   (abs (cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 enx)))))))
Test Program:
(defun c:test1 ( / ent )
    (if (setq ent (car (entsel)))
        (getentcolour ent)
Visual LISP
(defun getobjcolour ( obj / col )
    (if (= acbylayer (setq col (vla-get-color obj)))
        (vla-get-color (vla-item (vla-get-layers (vla-get-document obj)) (vla-get-layer obj)))
        col
Test Program:
(defun c:test2 ( / ent )
        (getobjcolour (vlax-ename->vla-object ent))
Message 7 of 8
cncah
in reply to: Lee_Mac
Thanks!
Message 8 of 8
dgorsman
in reply to: cncah
Getting the TrueColor property (returns as an AcCmColor object) provides a number of useful methods and properties, which also work with some useful constants like acRed and acByLayer.  These can make the code a little more human readable.
”Boost
