*Martin Shoemaker
Message 41 of 45 (240 Views)
Re: Why does Autodesk ignores the LISP community?
08-30-2004 02:59 PM in reply to: JeremyD
It would be great if you'd release the code. The more examples, the better, especially when they're "real world". Martin Joel Roderick wrote: > Jason, > I put a copy of the paper here: > www.globaldialog.com\~jroderick\CP21-3.zip > > The c: issue is explained in the help file: > "There are two similar styles that can be used to program AutoLisp code to > handle the ObjectDCL events. But first, to answer a question some of you > may have, you will notice that ObjectDCL calls its events as C:xxx defun'd > functions. This is done because of the limitation ObjectARX imposes on > mechanisms to call AutoLisp functions from some ObjectARX dialog boxes. > Rather then setup ObjectDCL to defun some events as C:xxx and others as xxx, > C:xxx is used as the standard. The first programming style defines all the > event defun's inside the main defun. This allows the program to be created > free of global variables. The second style allows global variables to be > used instead to organize information between the main defun and the event > defun's." > > If you look at my example in the AU paper, I actually localize the event > c:defuns. I tend to be anal about stuff like this :smileywink: > > When I was doing the CDG thing, I used ObjectDCL for CDGPurge. Since I have > dropped the website I have been thinking of just releasing the code as an > ObjectDCL example and letting people have fun with it. > > HTH, > Joel > > > > > "Jason Piercey" wrote in message > news:412e48be_1@newsprd01... > >>Hi Joel, >> >>I'd like to take a look at it, if you don't mind. >> >>Off the top of my head, some trouble I had with it >>was lack of documentation, and why on earth you >>need *all* of your functions defined like a command >>(with the c: prefix) That just doesn't make any >>sense to me. >> >>Thanks for the offer. >> >>-- >>Autodesk Discussion Group Facilitator >> >> >>"Joel Roderick" wrote in message >>news:412e4453_1@newsprd01... >> >>>Jason, >>>You may find the AU class material I did to be useful. It walks you >> >>through >> >>>step by step on creating a project. Not sure if they still have them up >> >>on >> >>>the website, so if you need it, let me know. >>> >>>Joel Roderick >> >> > >
diagodose2009
Message 42 of 45 (222 Views)
Why does the LISP_community ignores C++LISP?
08-24-2011 07:33 PM in reply to: *Laurie Comerford
Your question: Autodesk ignores the LISP community ?
But my question :Why does the LISP_community ignore the language C++LISP?
MyAnswer: i can not understand...........
Edited by
Discussion_Admin
azrdgldr
Message 43 of 45 (213 Views)
Re: Why does the LISP_community ignores C++LISP?
08-24-2011 08:54 PM in reply to: diagodose2009
Diagodose, No disrespect intended, but I think no one here in this forum cares for what you are peddling.  Keep your C++ lisp in the classifieds, maybe someone there cares.
stevor
Message 44 of 45 (180 Views)
08-25-2011 07:07 AM in reply to: azrdgldr
Perhaps Diag was wasjust demonstrating the very reason, in a very subtle way: Autodesk has endeavored to divert attention away from autolisp, towards methods that can provide further income, to Autodesk. As John Walker commented two decades ago, the autodesk team did not have the amount of time or knowledge to make all the various 'tools' that the established CAD providers had, so integrated 'arcane' Lisp into the autocad, in 1986. Then ambitious users could do CAD, for far less money. For years it allowed faster 'work' and extended capabilities, allowing more, much more; maybe too much. Either way Diag, very, very subtle.
S
Valued Mentor
gasty1001
Message 45 of 45 (144 Views)
08-25-2011 10:49 PM in reply to: diagodose2009
May be you need to make a better effort in "marketing", better communication, better redaction and explanations to the answers you post here,  posting some good documention, examples. Posting under a real name also should help.
I think that no body will care about a new programming language without a good reason to do it: better and easier sintaxis, performance improvements, a modern IDE (which AutoLISP has not), community support,  etc.
So, evaluate honestly if you have any hope to succeed trying to introduce a new programming language to the AutoCAD developers community. If you are trying to make money with this, please say it cristal clear, if you not, may be going to open source it's an alternative.
Gaston Nunez
