please i need help to explode this drawing , ican't explode the block.
please advice,
please advice,
EDIT: I could've sworn i've included an image <inline> on this post.
Anyhoo. See attached file
may b this block created without allowing explode option; anyway
1) use "block editor" copy the objects.
2) exit block editor with/without save.
3) simple Paste
check the attachment.
(Y)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
3) simple Paste
(Y)
Don't know the reason why this thread is zombified. or is it an entirely different issue, but whats obvious is, the block is not scaled uniformly, hence it cannot be exploded.
uncheck scale uniformly
pBe
[Just in case it's relevant to anyone: While the "Scale Uniformly" and/or "Allow Exploding" options in defining a Block may be the answer for the recent revival posts on this old thread, be aware that at the time of the original post, neither of those options existed. They came along in later versions.]
Noted
