Visual LISP, AutoLISP and General Customization
Where to find documentation?
1 REPLY 1
tomislav.buturajac
305 Views, 1 Reply
I had been absent with lisp programming in Autocad and I'm interested where to find documentation about acad api like functions acet-file-writedialog, acet-ui-progress-init and others. Is is within Autocad installation?
Best regards!
1 REPLY 1
in reply to: tomislav.buturajac
The ACET* library is not really documented, at
least not up to date as far as I know, probably because it wasn't meant to be
made available to everybody.
There is a help file however and I've attached
here, but it's an old one and I know that the library changed since then, but
hey, its BTN stuff (Better Than Nothing).
You should consider that all code based on the
ACET* library won't work if the library modules acetutil.arx, acetutil*.fas are
not loaded, so it's a good idea to test this in your code.
HTH
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
I
installation?
Best regards!
”Boost
